Gareth_L
9 months agoForum Team
Hello vrtual_climber.
Thanks for your post.
Sorry to hear about the issue with your hub dropping connection.
With this being an ongoing fault, I would like to take a look into this for you and see what may be causing the issue.
More than likely the hub is on its way out. If so then we can arrange for an engineers to attend.
If you can check the logo top right of your screen that would be great.
Gareth_L
Related Content
- 3 months ago
- 8 months ago
- 3 months ago
- 2 months ago
