carl_pearce
11 months agoCommunity elder
So, one thing you could try is to plug a wired device (Laptop or PC/MAC) directly into the HUB (Ensure nothing else wired is connected), reboot the HUB, and that device should get an IP address (Not the standard 192.1.68.0.x mind you) and internet access.
You could then make a note of the MAC address of the device's ethernet adapter, then use the 'Clone MAC' advanced settings in the Tenda to 'pretend' to be the wired device (You can type in the MAC address, OR connect the wired device to the Tenda to copy the address directly).
https://www.tendacn.com/faq/2168.html
Swap over from the wired device to the Tenda, then reboot both the HUB and Tenda again.
- marko820711 months agoOn our wavelength
Will try do that Carl tomorrow when I get chance! Worth a shot, cheers
Related Content
- 3 months ago
- 11 months ago
- 2 years ago
- 8 months ago
- 7 months ago
