11 months agoAlessandro Volta
Given we know there are possible issues with the 2.5Gb/s port and that there is no gain to be had for the Tenda it might be best to use a 1Gb/s port to avoid risk of sudden service failure due to an over night firmware update.
Take a look at the thread below, find the entry from Tudor ... the steps for switching to modem mode are critical both for the Hub and for your Tenda Router.
https://community.virginmedia.com/t5/Networking-and-WiFi/Virgin-Hub-5-won-t-work-in-Modem-Mode/m-p/5424539
marko8207
11 months agoOn our wavelength
Sorry, I know my post was a bit long! (I rambled) but did all the steps suggested in that very thread to no avail including using the 1GB ports.. Only seems to connect to the Tenda on router mode
Related Content
- 3 months ago
- 11 months ago
- 2 years ago
- 8 months ago
- 7 months ago
