carl_pearce
11 months agoCommunity elder
Looking at the spec of the Tenda MX21 Pro it only has 1Gbps ethernet ports so no reason to use the 2.5Gbps ethernet port on the HUB 5 (Limited to around 900-940Mbps).
Ensure you only have one ethernet connection to the HUB 5 (One of the 1Gbps ethernet ports to the main Tenda node WAN port), then reboot both the HUB and the Tenda.
marko8207
11 months agoOn our wavelength
I have tried the other ports out on the hub 5 into the Tenda but same result (flashing red).
Hub Firmware is LG-RDK_7.6.15-2306.5 however at present, (in router) mode, I am connected to and using the the 2.5gb port on the Hub 5 into the mesh and that works, just not in Modem mode.
Related Content
- 3 months ago
- 11 months ago
- 2 years ago
- 8 months ago
- 7 months ago
