LindaRD
8 months agoJoining in
Hub 3.0 now showing red light
My Hub 3.0 has been showing an orange/red light since yesterday lunchtime. The Hub appears to be working fine, with no loss of internet, and is barely warm if anything to the touch. I have checked s...
- 8 months ago
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
