James19790
2 months agoTuning in
Thanks for the reply - really appreciate that and it was advice from a call centre!!
The error message I get in the car is to check the DHCP settings so I think it must be something to do with the fact that the car can’t find a single stable ip to connect to perhaps and is finding various APs and is confused - but my technical knowledge is only slightly better than your cat so not 100% sure!
ive tried turning all but the main mesh nodes off and it still wouldn’t connect so thought it was worth trying it again in router mode - but couldn’t see why that would work just didn’t have any other suggestions. And Tesla just say to reset the car - which also doesn’t work!
James19790
This is error message in Tesla
Related Content
- 3 months ago
- 4 months ago
- 3 months ago
- 11 months ago
