It's not possilbe to get faster than 90Mbps (ish) from the Tenda MW3 with 10/100 ethernet ports so you either:
- Don't have Tenda MW3.
- Tenda have made a mistake on their site in the tech specs.
- You are mistaken in your setup.
Well, this is a little embarrassing. Please forgive an old man and his less than perfect memory who's feeling more than a little foolish right now !! I should have checked my kit first before questioning you guys here - my apologies to you all ! I think the 'blatantly stupid mistake' has just been exposed.
You are right - I don't have an MW3 set - I have the "Tenda MW6-3 Whole Home Mesh Wi-Fi System" which is 10/100/1000 enabled. I was clearly getting my 6s and 3s all muddled up! That explains the fast WiFi speeds when standing anywhere near the Hub3 and first node.
So now that we've established which mesh system I actually have, can I assume that the steps 1-7 in my last post are otherwise correct? Is there anything else I need to do or settings I need to change before I proceed with the list?
Related Content
- 6 months ago
- 2 months ago
- 11 months ago
