There are two passwords - one for settings and one for wifi - have you tried them both?
Also try it ion a laptop/computer connected directly to the Hub on an ethernet cable - rather than over wifi.
- Deanrwatson11 months agoJoining in
Yes, to both questions.
Thanks. I tried them before posting. Followed the "official" advice verbatim
- Gareth_L11 months agoForum Team
Hello Deanrwatson.
Thanks for your post.
Sorry to hear you are having an issue with your hub not allowing access to the settings.
I'd like to take a look into this for you and arrange a hub swap as it sounds like the current hub may be faulty.
If you can check your logo at the top right of your screen that would be great.
Gareth_L
Thanks for those details Deanrwatson.
Can you please keep this post updated once the replacement hub has arrived, or if you have any issues after you have set this up.
Gareth_L
Related Content
- 16 days ago
- 5 months ago
- 18 days ago
- 2 months ago
- 12 days ago
