Are you sure that ethernet connected devices are dropping out at the same time as the wifi ones ? If they are it would suggest a network/Hub issue rather than the more common wifi interference. So, can you do this...
___________________
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Thanks John
1 | 203000000 | 4.6 | 40 | 256 qam | 9 |
2 | 211000000 | 4.6 | 40 | 256 qam | 10 |
3 | 219000000 | 4.8 | 40 | 256 qam | 11 |
4 | 227000000 | 4.8 | 40 | 256 qam | 12 |
5 | 235000000 | 4.9 | 40 | 256 qam | 13 |
6 | 243000000 | 4.9 | 40 | 256 qam | 14 |
7 | 251000000 | 5 | 40 | 256 qam | 15 |
8 | 259000000 | 5 | 40 | 256 qam | 16 |
9 | 267000000 | 5 | 40 | 256 qam | 17 |
10 | 275000000 | 4.9 | 40 | 256 qam | 18 |
11 | 283000000 | 5 | 40 | 256 qam | 19 |
12 | 291000000 | 5 | 40 | 256 qam | 20 |
13 | 299000000 | 5.1 | 40 | 256 qam | 21 |
14 | 307000000 | 5 | 40 | 256 qam | 22 |
15 | 315000000 | 5 | 40 | 256 qam | 23 |
16 | 323000000 | 5.1 | 40 | 256 qam | 24 |
17 | 331000000 | 5.3 | 40 | 256 qam | 25 |
18 | 339000000 | 5.4 | 40 | 256 qam | 26 |
19 | 347000000 | 5.3 | 40 | 256 qam | 27 |
20 | 355000000 | 5.3 | 40 | 256 qam | 28 |
21 | 363000000 | 5.4 | 40 | 256 qam | 29 |
22 | 371000000 | 5.4 | 40 | 256 qam | 30 |
23 | 379000000 | 5.5 | 40 | 256 qam | 31 |
24 | 387000000 | 5.5 | 40 | 256 qam | 32 |
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 | Locked | 40.3 | 8597 | 0 |
2 | Locked | 40.3 | 8605 | 0 |
3 | Locked | 40.3 | 8694 | 5 |
4 | Locked | 40.3 | 8593 | 7 |
5 | Locked | 40.3 | 8626 | 5 |
6 | Locked | 40.9 | 8779 | 0 |
7 | Locked | 40.3 | 8708 | 0 |
8 | Locked | 40.3 | 8765 | 0 |
9 | Locked | 40.3 | 8707 | 0 |
10 | Locked | 40.3 | 8638 | 0 |
11 | Locked | 40.9 | 8659 | 0 |
12 | Locked | 40.3 | 8891 | 0 |
13 | Locked | 40.3 | 9045 | 0 |
14 | Locked | 40.9 | 9078 | 0 |
15 | Locked | 40.3 | 9077 | 1 |
16 | Locked | 40.9 | 8935 | 3 |
17 | Locked | 40.3 | 8880 | 0 |
18 | Locked | 40.3 | 8885 | 0 |
19 | Locked | 40.9 | 8975 | 0 |
20 | Locked | 40.3 | 9113 | 0 |
21 | Locked | 40.9 | 9007 | 0 |
22 | Locked | 40.3 | 8822 | 0 |
23 | Locked | 40.3 | 8704 | 0 |
24 | Locked | 40.3 | 7953 | 0 |
- emmjay12311 months agoJoining in
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 60300000 32 5120 16 qam 1 2 32600000 32 5120 64 qam 9 3 39400000 32 5120 64 qam 4 4 53700000 32 5120 64 qam 2 Upstream bonded channels
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 ATDMA 0 0 2 0 2 ATDMA 0 0 1 0 3 ATDMA 0 0 4 0 4 ATDMA 0 0 0 0 - emmjay12311 months agoJoining in
21/03/2024 19:48:38 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2024 19:47:35 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2024 14:14:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2024 13:25:1 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/03/2024 07:22:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2024 01:25:0 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/03/2024 11:22:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/03/2024 13:25:0 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/03/2024 09:53:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2024 19:53:59 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2024 10:31:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/03/2024 00:30:8 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/03/2024 07:07:13 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/03/2024 11:55:7 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/03/2024 09:33:32 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/03/2024 20:25:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/03/2024 17:53:36 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/03/2024 15:16:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/03/2024 05:53:36 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/02/2024 20:52:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;C
Related Content
- 5 months ago
- 3 months ago
- 2 months ago
