DForeman
4 months agoJoining in
Devices not connecting to WiFi Pod
Hi, My devices don't seem to be using the WiFi Pod to connect to a better signal and instead connect to the Hub which is further away and not giving as good a signal. I've attached an image showin...
- 4 months ago
VM Hubs and VM Pods use a common SSID - this means whatever your device chooses can not be overridden.
The only solution is to return the VM Pod and replace it with a retail Wi-Fi Repeater that can easily be configured to repeat the Wi-Fi signal on a different SSID.
E.g From the VM Hub SSID : VM1234567 and from the Repeater SSID: VM1234567_EXT1
now it would be possible to select either VM1234567 or VM1234567_EXT1 from the devices Wi-Fi menu.
