buchosmambo's avatar
buchosmambo
Constant problems with ethernet connection - New Hub
Hi All - I am still experiencing a lot of problems with 1G package.
Approx month or two ago I received new Hub5 as old one just broke down.
Things were bit better for few weeks but then recently online gamming became again - IMPOSSIBLE!!! I noticed that I am getting quite few post errors with new hub after the restart. Does this look normal?
3.0 Downstream channels
14110000005.337QAM 2561
24190000005.338QAM 2562
3427000000538QAM 2563
44350000004.238QAM 2564
54430000003.437QAM 2565
64510000004.137QAM 2566
74590000004.938QAM 2567
84670000005.338QAM 2568
94750000005.438QAM 2569
104830000005.538QAM 25610
114910000005.738QAM 25611
124990000005.838QAM 25612
135070000005.738QAM 25613
145150000005.638QAM 25614
155230000005.838QAM 25615
16531000000638QAM 25616
175390000006.338QAM 25617
185470000006.338QAM 25618
195550000006.438QAM 25619
205630000006.438QAM 25620
215710000006.538QAM 25621
225790000006.538QAM 25622
235870000006.538QAM 25623
245950000006.538QAM 25624
256030000006.638QAM 25625
266110000006.538QAM 25626
276190000006.638QAM 25627
286270000006.538QAM 25628
296350000006.338QAM 25629
306430000006.338QAM 25630
316510000006.238QAM 25631
326590000006.338QAM 25632
1Locked3718985
2Locked38183139
3Locked381610
4Locked38170142
5Locked37198141
6Locked37175106
7Locked3818051
8Locked3816760
9Locked38213117
10Locked3815762
11Locked3813842
12Locked3813646
13Locked3813446
14Locked3815769
15Locked3813769
16Locked3813064
17Locked3812130
18Locked381279
19Locked3812011
20Locked3810810
21Locked3811510
22Locked3811128
23Locked3811325
24Locked3810723
25Locked3812120
26Locked381260
27Locked381200
28Locked381040
29Locked381040
30Locked381100
31Locked38970
32Locked381000
3.1 Downstream channels
159944K1840QAM 40961108
159Locked406.340708528310
3.0 Upstream channels
04960000039.55120QAM 649
14310000038.55120QAM 6410
23660000038.55120QAM 6411
33010000037.85120QAM 6412
42360000037.55120QAM 6413
0ATDMA0000
1ATDMA0010
3ATDMA0020
4ATDMA0000
3.1 Upstream channels
141034.02KQAM 256
14OFDMA2007400000000
  • jpeg1's avatar
    jpeg1
    Interesting in those last readings that there is strong interference around 525MHz. It wasn't there previously.
    • buchosmambo's avatar
      buchosmambo
      I know... I checked cables and it all appears to be correct. Only thing I can think off is that cabinet at the end of the road being constantly opened - I will just wait for VM support to get back .....
      • Carley_S's avatar
        Carley_S
        Do you have only the one wired device to test the connection on? Are you able to check to see if you get the connection issues wired on other devices?
        Have you tried checking if the wired connection has any issues when the hub is in modem mode rather than router mode?
  • jpeg1's avatar
    jpeg1
    The BQM on the link you posted earlier looks very good apart from one brief episode of packet loss.
    buchosmambo
    Me again - what a nightmare - lost for words.
    Basically few weeks ago I received message from VM asking to restart the hub as their monitoring system discovered something wrong - I restarted the modem and then within few days I get the message saying that I need new cable installed - 3 cancelled visits later; I finally had new cable installed on 11th of November.
    During the install of a new cable to our property, next door neighbor gets outside and speaks to Avon Cable contractors that she got cat out; I am thinking that's weird (their contractor made me aware that they might have to cut my old cable and that I will lose connection for few minutes so I was ok with that) while next door reports lack of service; I am still ok and have no interruptions. Contractor proceeds with cable installation and within few minutes they are ready to leave and As they were driving away; I briefly lost connection for circa 10 mins but everything was back to normal. I checked usual stats in the hub and noticed that signal on DS dropped down to around 0 (or few decimals within 0 ) - not sure of this is fine or not..... I also performed usual speed test but that was quite low - in the range of 100M or 700M near the Hub  - My package is 1G - but I though give it another day and check then .
    Today I noticed VM02 van in front of our house messing about in the junction box in the pavement in front of our house so I got out saying that my cable was replaced on Monday in case if he was doubled booked - turns out he was there to fix next doors supply as they got cut out yesterday. Hmm..... strange as that junction is on the opposite boundary to our next door so I would assume that only our cable runs in there straight through front garden into box on the wall to our house but as it stands there is another cable there - but no one knows its run/ path to next door. According to VM02 engineer - that cut cable was still live (signal detected) Anyways.... fast forward few minutes; he had to install temp cable running through our front; along the wall, above porch roof to next door as he was short of cable and that was the only (apparently) way he could have done it  so entire cable length is pretty lose.  He left exposed cable on sticking out of junction box which in my view creates trip hazard, also leaving exposed cable on the driveway where my son parks his car so no doubt that cable will get damaged pretty quickly.
    I called VM today asking where this will rectified but I got usual; lack of availability and that VM operator will call me back - needles to say nobody called me back.
    What is the recommended approach here - has anyone got any recommendations of how can we get this sorted please? Very awkward situation that just leads to unnecessarily problems!
    Any help will be greatly appreciated.
    • John_GS's avatar
      John_GS
      Hi buchosmambo
      Thanks for posting and welcome back to the community. Sorry to hear of the exposed cabling.
      I'll send you a PM now to get some details and will reach out to the Field Team.
