2 months agoAlessandro Volta
Look at the 3.0 Downstream channels, there are high numbers of Pre-RS Errors but much worst also many Post RS Errors ( i.e. uncorrectable errors ). If these error counts are still rising a local noise fault may still be an issue.
Check all the internal coax cables are securely fitted to your VM Hub and to your VM TV equipment.
Check external connection boxes still have covers intact and not letting rain onto the cables / splitters.
Related Content
- 3 months ago
- 4 months ago
- 10 months ago
