bobradamus
3 months agoTuning in
Connecting 360 TV over home LAN to router in modem mode
Hey everyone, I’ve got a slightly more complicated home network than most - for several reasons including WFH network resiliance. I’m using a Teltonika RUTX08 router as the gateway to two Internet ...
- 3 months ago
I have a similar setup, VM and also a FTP 1G/1G, with the VM hub in modem mode. I use a UniFi UDM Pro router and have 50% of traffic going across each link. In my routers setup there is something called policy based routing and I use this for two things. To direct all traffic from my V6 to the VM hub and all traffic for 192.168.100.1, where ever it comes from, to the VM hub. Maybe there is something in your router that will do the same. I think it probably uses iptables to send data the correct way.
