carl_pearce
7 months agoCommunity elder
They probably cheaped out and use a 10/100, or even 10Mbps, ethernet port which the HUB 5 is known to have issues with.
You'll prob need to buy a cheap switch like below, to connect between the HUB 5 and device:
https://www.amazon.co.uk/TP-Link-LS1005G-Wallmount-Ethernet-Splitter/dp/B07VWB347G
For WiFi devices you'll need to split the SSID into two, one for 5Ghz, and one for 2.4Ghz.
Related Content
- 6 months ago
- 7 months ago
- 3 months ago
- 6 months ago
