steveD360's avatar
steveD360
Just joined
7 hours ago
HDMI switching does not work after upgrade to 360
 I use an HDMI switcher so I can choose what to send to my TV. This worked fine before upgrade to 360 but now there is no signal. If I connect both my 360 boxes to the switch it works fine. If I connect a 360 and PC to the switch the 360 signal stops.
Is there a setting I can change somewhere or can I remove the 360 upgrade and revert to V6?
1 Reply
  • Tavis75's avatar
    Tavis75
    Super solver
    Possibly an HDCP issue? You can buy devices that are meant to strip the HDCP signal from the output so maybe could put one of those in the chain before the switcher? Though last time I looked they were about £50 so maybe not ideal just to test. Though odd that it works with two 360s connected.
    There is generally no way to revert back to the V6, many people have tried due to the inferior user experience and multiple missing features, but other than a few isolated cases where people have very much been switched against their will and managed to get a box swap, then generally VM are not willing to do it. They want everyone on 360s and then eventually Stream boxes.
