So...engineer came today and said that at the cabinet I was connected to a very old line that was feeding in to multiple splitters in to the flats where I live. So he has moved me on to a new spare slot in the cabinet and directly connected me without the splitters and then fitted an attenuator. He also directly connected the port I am using to the cable outside and moved the isolator in to the socket that is actively being used, so I now have a direct connection from outside in to the socket I use for the modem. This seems to have solved the noise issue on the downstream and the power levels (downstream power seems to be just in spec)
However, I still have no 3.1 upstream channel, and am still seeing T3 timeouts on the upload. Could somebody please give these stats a once over? I will see how it fares in terms of any packet loss or drop outs over time, but for now the speeds are fine and the latency is as expected. The engineer said that after some time, the 3.1 channel should appear but I am not so sure that will be the case. Also just to confirm, it is an HFC connection.
3.0 Upstream channels
0 | 60300000 | 47.5 | 5120 | QAM 64 | 9 |
1 | 53700000 | 48 | 5120 | QAM 64 | 10 |
2 | 46200000 | 47.8 | 5120 | QAM 64 | 11 |
3 | 39400000 | 46.5 | 5120 | QAM 64 | 12 |
4 | 32600000 | 46 | 5120 | QAM 64 | 13 |
5 | 25800000 | 45.5 | 5120 | QAM 64 | 14 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
3.0 Downstream channels
1 | 298000000 | 7.6 | 44 | QAM 256 | 21 |
2 | 138000000 | 7.6 | 45 | QAM 256 | 1 |
3 | 146000000 | 7.5 | 45 | QAM 256 | 2 |
4 | 154000000 | 7.5 | 44 | QAM 256 | 3 |
5 | 162000000 | 7.4 | 44 | QAM 256 | 4 |
6 | 170000000 | 7.3 | 44 | QAM 256 | 5 |
7 | 178000000 | 7.2 | 44 | QAM 256 | 6 |
8 | 186000000 | 7.2 | 44 | QAM 256 | 7 |
9 | 194000000 | 7.4 | 44 | QAM 256 | 8 |
10 | 202000000 | 7.4 | 44 | QAM 256 | 9 |
11 | 210000000 | 7.7 | 44 | QAM 256 | 10 |
12 | 218000000 | 7.7 | 44 | QAM 256 | 11 |
13 | 226000000 | 7.9 | 44 | QAM 256 | 12 |
14 | 234000000 | 7.9 | 44 | QAM 256 | 13 |
15 | 242000000 | 7.8 | 44 | QAM 256 | 14 |
16 | 250000000 | 7.7 | 44 | QAM 256 | 15 |
17 | 258000000 | 7.7 | 44 | QAM 256 | 16 |
18 | 266000000 | 7.6 | 44 | QAM 256 | 17 |
19 | 274000000 | 7.7 | 44 | QAM 256 | 18 |
20 | 282000000 | 7.7 | 44 | QAM 256 | 19 |
21 | 290000000 | 7.6 | 44 | QAM 256 | 20 |
22 | 306000000 | 7.6 | 44 | QAM 256 | 22 |
23 | 314000000 | 7.5 | 44 | QAM 256 | 23 |
24 | 322000000 | 7.3 | 44 | QAM 256 | 24 |
25 | 330000000 | 7.3 | 45 | QAM 256 | 25 |
26 | 338000000 | 7.6 | 44 | QAM 256 | 26 |
27 | 346000000 | 7.6 | 45 | QAM 256 | 27 |
28 | 354000000 | 7.3 | 44 | QAM 256 | 28 |
29 | 362000000 | 7.3 | 44 | QAM 256 | 29 |
30 | 370000000 | 7.6 | 45 | QAM 256 | 30 |
31 | 378000000 | 7.6 | 45 | QAM 256 | 31 |
1 | Locked | 44 | 0 | 0 |
2 | Locked | 45 | 0 | 0 |
3 | Locked | 45 | 0 | 0 |
4 | Locked | 44 | 0 | 0 |
5 | Locked | 44 | 0 | 0 |
6 | Locked | 44 | 0 | 0 |
7 | Locked | 44 | 0 | 0 |
8 | Locked | 44 | 0 | 0 |
9 | Locked | 44 | 0 | 0 |
10 | Locked | 44 | 0 | 0 |
11 | Locked | 44 | 0 | 0 |
12 | Locked | 44 | 0 | 0 |
13 | Locked | 44 | 0 | 0 |
14 | Locked | 44 | 0 | 0 |
15 | Locked | 44 | 0 | 0 |
16 | Locked | 44 | 0 | 0 |
17 | Locked | 44 | 0 | 0 |
18 | Locked | 44 | 0 | 0 |
19 | Locked | 44 | 0 | 0 |
20 | Locked | 44 | 0 | 0 |
21 | Locked | 44 | 0 | 0 |
22 | Locked | 44 | 0 | 0 |
23 | Locked | 44 | 0 | 0 |
24 | Locked | 44 | 0 | 0 |
25 | Locked | 45 | 0 | 0 |
26 | Locked | 44 | 0 | 0 |
27 | Locked | 45 | 0 | 0 |
28 | Locked | 44 | 0 | 0 |
29 | Locked | 44 | 0 | 0 |
30 | Locked | 45 | 0 | 0 |
31 | Locked | 45 | 0 | 0 |
3.1 Downstream channels
159 | 128 | 4K | 2511 | QAM 4096 | 768 |
159 | Locked | 44 | 6.5 | 981962 | 0 |
Cable Modem Status | Online | DOCSIS 3.0 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 6 |
DOCSIS 3.1 channels | 1 | 0 |
Related Content
- 9 months ago
- 7 months ago
- 3 months ago
- 8 months ago
- 5 months ago
