carl_pearce
3 months agoCommunity elder
Your upstream power levels are out of spec, and it appears you are in an area that does not currently support DOCSIS 3.1 upstream, so 6 3.0 channels are being used instead, which should still be sufficient for 104Mbps.
You also have a SNR issue on a couple of downstream channels.
Engineer visit required.
Sauce245
3 months agoOn our wavelength
Ah...OK. Thanks for looking at it. I guess I will need to hop on the phone to VM then...
- carl_pearce3 months agoCommunity elder
Or wait a few days for a reply on here.
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
- 8 months ago
- 4 months ago
