crackerjack
11 months agoJoining in
new router for 1g speed?
Hi I had gone for a new contract on the 28th March. At the moment my speeds are still showing 500 gb . I went for the 1g speed which works out at £60 a month instead of £80. I received an email th...
- 11 months ago
The Hub 4 is suitable for the 1Gb service. The WiFi is not, & will max out at 600 Mb per device due to the older WiFi standard in use. Make sure you are testing via wired means.
