jackydog
6 months agoTuning in
Low speeds
Hi I'm paying for 250Mbps but currently only getting 96 Mbps download on ethernet and slightly less on wifi on my main pc what can I do?
Link speed (Receive/Transmit): 100/100 (Mbps)
Link-local IPv6 address: fe80::7764:9ac2:47e3:2797%13
IPv4 address: 192.168.
IPv4 DNS servers: 194.168.4.(Unencrypted)
194.168.8.100 (Unencrypted)
Primary DNS suffix: cable.virginm.net
Manufacturer: Realtek
Description: Realtek PCIe GbE Family Controller
Driver version: 10.75.324.2025
Physical address (MAC):
A CAT 5e cable is all we need for a reliable 1 Gbps connection.
I don't read the PC is directly network cable connected to the VM Hub - is that the case ?
Or is there a 10/100 switch or 10/100 Powerline adaptor or some other network kit involved ?
Look carefully at the network socket on the PC, it needs to have 8 contacts and they all need to be undamaged to connect at 1Gbps. Same goes for the VM Hub end, where there are a choice of 4 network sockets to test with.
Also what does the speed(Mbps)in the hub app mean because some of my connected devices show speeds greater then the 250 I am paying for
It means nothing unless by wire.
Ok but why have all the devices got different values?
Just for completeness, do a full 60 sec pinhole reset of the Hub. Let it reboot and update itself. Do not manually reboot at this stage. Remove all Ethernet cables before hand.
Shielding on Cat 8 cable ends can cause issues and are not needed with the VM Hub. Stick to Cat 5e or Cat 6.
