carguy143
3 months agoDialled in
I have the Gig 1 service and Hub 5x but use my own WiFi 6E mesh system with hardwired backhaul. Here's how to do it and avoid NAT problems.
Set the mesh router's WAN to DHCP and connect to a LAN port on the Hub 5x. Copy the IP address your router has received.
Enter the Hub 5x settings and set the IP address your router has been given as a DMZ.
Disable the WiFi on the Hub 5x.
- legacy13 months agoAlessandro Volta
Thats still no good double NAT which would stop people using NAT loopback if hub 5x don't support or gets removed
Related Content
- 2 years ago
- 2 months ago
- 3 months ago
- 10 months ago
- 11 months ago
