Hi Raptert,
As you are using the Hub5X i am assuming you are a XGSPON customer with Full Fibre.
The XGSPON network you are using is not quite there yet, there is still parts of the VirginMedia network that still require some attention, you can generally see this by running a traceroute to 8.8.8.8, there you will see each hop as it passes through Virgin's network.
I am also a XGSPON customer like you, i have quite a techy setup but im wired directly into the router on a Gig2 package. When i run a traceroute command to 8.8.8.8 there are hops in the Virgin Media network that are higher than most other providers. I can see response times of 1ms - 2ms until i hit the core network which then jumps to 5ms - 7ms depending on the route.
The routing is still a bit 'odd' and as mentioned above Virgin are working on making their network better, the decommissioning of their HFC coax network was the first step, and it should slowly start to get better as they upgrade and improve their network. - So this is expected over the likes of Openreach FTTC/P.
To answer your question fully, your best bet would be to use WiFi (before everybody screams; hear me out). - I would invest in a reputable good WiFi 6 router, WiFi6 is supported on your PS5 and any third party WiFi 6 router will be better than the WiFi 6 on the default router by a fair margin in signal strength, speed and quality.
There are other options, such as powerline adapters but they use plug socket ring main circuit to provide a signal from one end to the other, and these aren't normally great for gaming especially for older houses that have a split RCD fuseboard and upstairs and downstairs sockets sometimes tend to be on completely seperate circuits, thus introducing excessive latency.
To conclude; i would invest in a WiFi 6 router, you can plug this into your Hub5X and use that for your PS5 instead, as you will get a much better quality connection. The Hub5X is a WiFi 6 router, but again a dedicated WiFi 6 router should perform a lot better than the 5X which is also known for having Wifi range issues (Hence why VM offer the free boosters when you sign up if you experience signal issues).
Hope that info helps.
Routing isn't related to the cable network being decommissioned. What are you seeing high latency to? Would expect some pretty low hops followed by timeouts and some increase after, how high that is depending on where in the country you are.
- suttonscloud3 months agoOn our wavelength
That’s not what I was saying, sorry must have worded it wrong. The routing on XGSPON does have some issues. There is a certain hop to the core network that can vary, one is as low as 4-5ms, and then there’s another that I’m commonly routed through that is 10ms (almost double).
seems random when it changes, but if I go across on my BQM you can see the latency decline and stay halved, and then come back up again.
Virgin has had congestion and latency issues for a while, RFoG helped reducing the coax distance for possible interference, but wasn’t great. This is reflected in parts of their network like I said. It’s getting better; but there’s still stuff that needs to be worked on. There’s going to be old stuff floating around the network for a while, and with the rollout of more full fibre premises this should theoretically get better as virgins infrastructure improves.
- IPFreely3 months agoFibre optic
Not ideal. Have a traceroute showing that?
Related Content
- 2 years ago
- 2 months ago
- 3 months ago
- 10 months ago
- 11 months ago
