To conclude; i would invest in a WiFi 6 router, you can plug this into your Hub5X and use that for your PS5 instead,
With the lack of Hub 5x Modem mode, this is quite odd advice to give.
Why does that seem like odd advice to give?
You’d get a double NAT, which in 99% of cases doesn’t impact gaming experience. - I gamed on a Strict NAT for years.
the only odd thing here is that you think everybody who invests in a router runs their old one in Modem Mode, which is bonkers.
Modem mode works on the 5X you just need to do some research and you can get it working, there has been posts all over the forum about this method for months. - it only becomes pointless when you have a 2gb connection (like me) and modem mode only works on the 1gb ports.
a WiFi 6 router would be absolutely fine, set up in access point mode running off the 5X.
Related Content
- 2 years ago
- 2 months ago
- 3 months ago
- 10 months ago
- 11 months ago
