Hi BubblesLittle
You won't get full speed on wifi connections.
Have you used an ethernet connection to test the speed? Preferably using a PC/laptop.
Have you ensured that the ethernet cable is snugly connected? Also have you tried a different ethernet cable and/or port? Ethernet cables can deteriorate
If so check that the adapter settings are set to either 1.0 Gbps Full Duplex or 2.5G
Press the Winows key and type in ethernet. Then select ethernet settings. Then change adapter settings. Double click Internet and it should show the speed as indicated on the picture below.
If you need to change it change it, click Properties followed by Configure then scroll down as shown on the right and set the value to 1.0 Gbps Full Duplex.
computer is connected by ethernet it don't matter what device i use still same speed. nothing has changed all the same as when it was working right only thing that changed is we are not in contract with virgin anymore
Related Content
- 4 months ago
- 3 months ago
- 8 months ago
