on 20-07-2012 15:28
Hi, firstly I'd just like to say that before the R36 update I couldn't connect at all wirelessly. Now it's hit and miss. I can connect sometimes when the connection appears, but when I do connect it takes around 10 minutes to even connect to a web page.
The wired connection is amazingly fast and reliable.
I have another wireless router which I was using with the Super Hub and I could connect wirelessly with that, but my wired connection wasn't very reliable with that (Catch 22)
I'm on 2.4ghz and I've tried a number of channels, including auto. I've turned off the firewall filter settings and detection setting under the security page, but nothing seems to help. I can't even run inSSIDer from my wireless laptop to see which channel is the best because I can't get to the web page, so I've left it on auto.
Any help? I see this is a common problem.
I refuse to use the call centre as they have no idea what they are on about and are adamant on a remote connection, but I know all of my settings are as they should be as I've looked at the FAQs and other posts.
on 20-07-2012 18:37
on 23-07-2012 10:18
