Just joined
Stridey
NETGEAR WN2500RP and Superhub
Does anayone know if the NETGEAR WN2500RP will be compatible with the Superhub?
Please use plain text.
Steve_Brett
Re: NETGEAR WN2500RP and Superhub
Hi Stridey
From the blurb on their website it certainly appears to be compatible, however having read through your other thread regarding this, I must say I would also favour the switch to modem mode and fit a better router fix that was discussed in that thread.
Kind Regards,
Steve Brett
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
