  • 14
Markige
Message 1 of 5
v6 Remote code for Yamaha surround sound amp + sound levels lower?
Hey
I've tried some of the codes suggested online for yamaha but none seemed to work
Yamaha Natural Sound AV Receiver HTR-3065
Does anybody have any suggestions or can anybody confirm the definite code for this device? I want to make sure the code is right before going mad, to discount the possibility I'm not clicking everything in the right order Smiley Very Happy
Finally, has anybody else noticed that the sound output is much lower than the old Tivo box? Or is this a setting I can change somewhere?
Thanks,Mark
  • 14
Markige
Message 2 of 5
Re: v6 Remote code for Yamaha surround sound amp + sound levels lower?
You'd have thought that when virgin sent me to this forum they would make sure they had someone replying to the posts even if it's to say sorry they can't help ...
  • 6.22K
  • 232
  • 355
Message 3 of 5
Hi Markige,
Welcome to the community.
You should be able to find further codes on our  help link regarding programming your remote here.
I hope you're able to get this working and if you find the right code please let us know.
Kind regards
Rose
  • 14
Markige
Message 4 of 5
^Yes, as mentioned I have tried various codes and that link. None of which worked, so I need somebody to find out exactly which one it is please.......
this forum is quickly becoming the most laughable waste of space idea I've ever experienced!
  • 15.03K
  • 618
  • 1.02K
Message 5 of 5
Hi Markige
The codes are designed to work with TVs primarily so pairing with surround sound systems can be a bit hit and miss. Do you control the volume of the overall system using the TV volume or the separate volume on the surround sound?
If its using the TV volume, you can pair the remote up to your TV instead and still control the volume of the whole system.
Look forward to hearing from you
Craig
