TIGGER2203
Message 1 of 7
tv remote problem
Im trying to connect my remote to my v6 box so I can use the volume bottons, ive tried following the instructions in the help guide but its not connecting. Can someone help me please?
  • 16
Mastic01
Message 2 of 7
Re: tv remote problem
Did you mean connect remote to the tv for the volume??
TIGGER2203
Message 3 of 7
Yeah i did
  • 16
Mastic01
Message 4 of 7
Cool press tv & clear together until green light flash twice type in 0999 remote should flash hold channel up button until tv turns off then press ok to save ( may need to try a couple of times 🤞)
TIGGER2203
Message 5 of 7
Still not working
TIGGER2203
Message 6 of 7
Ive tried all that still nothing
  • 8.32K
  • 359
  • 588
Message 7 of 7
Hi TIGGER2203,
Welcome to the Community!
Really sorry to hear you're having trouble with your remote control volume setup.
If you've tried all the codes and the code search function but still can't set the volume, it's likely your TV isn't currently compatible with our remote control.
We're adding new codes all the time so check the list periodically and retry the volume set.
All the best! Smiley Very Happy
Josh
