shortstuff001
sound bar connection
Can I attach  sound bar directly to my v+box via an optical lead. Will it work. My tv does not have an optical port. Don't really want to get a new tv.
  • 8.63K
  • 584
  • 1.71K
Re: sound bar connection
Yes you can, if memory serves you also need to go into the 'Settings'  sound menu and enable the HDMI override to activate the optical output.
