ollie3000
remote issues
Hi, my remote isn't working properly, half the buttons have to be pressed twice to work, and the other half wont work at all, like the number buttons, and the play, pause and stop buttons.
the remote has brand new batteries
  • 7.25K
  • 812
  • 3.05K
Re: remote issues
Phone in a TV fault on 150 or 0345 454 1111.
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
