martina1
Just joined
problems in HA1
Hi anybody had problems in ha1 ? had freezing of picture, reported it but now nothing and update is, wont be fixed until tomorrow :-(((
  • 8.02K
  • 423
  • 1.31K
Re: problems in HA1
You can check to see if there are any reported service issues in your area using this link: http://my.virginmedia.com/faults/service-status
If it's not an area fault then the system will perform a few tests of your installation to see if there's anything obvious.
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
  • 5.78K
  • 214
  • 339
Re: problems in HA1
Hello martina1,
Thanks for posting on the community Smiley Happy
I would like to make sure everything's okay but unfortunately I'm unable to access your account so if you click on the purple envelope at the top right of the screen you will see another message from me requesting further information.
Speak to you soon.
Rose
