  • 37
Guest789789
poor sound quality
My virgin media v+hd box yet again has poor sound quality but it was alright about an hour ago
Jake
  • 6.68K
  • 262
  • 485
Re: poor sound quality
Hi Guest789789,
Welcome to the Community!
Sorry to hear you're having trouble with your sound.
Here's a few things you can try:-
  • Check all the connections at the back of the box and TV set
  • Try a different HDMI lead
  • Try a different HDMI port in the TV
Do you get any sound issue when using another device connected to the TV, such as a DVD player or games console?
Look forward to hearing from you!  Smiley Very Happy
Josh
  • 37
Guest789789
Yes it is connected to my Xbox one normally the sound quality and everything else is spot on and ive only ever had it running though my Xbox one Smiley Happy
Jake
  • 6.68K
  • 262
  • 485
Hi Guest789789,
Thanks for getting back to me!
If it's working through the Xbox then we can rule out the TV speakers as the cause of the sound issues.
We're you able to do the other checks with the cables?
Josh
  • 37
Guest789789
Thank you and shall I reboot my virgin box?
Jake
  • 6.68K
  • 262
  • 485
Hi Guest789789,
If you haven't done so already, a reboot may help although most issue with sound on the V+ box is usually down to the cabling.
Josh
