mauriceadams
Just joined
i need a replacement remote control for my V+ box, but cannot find the appropriate option on 150
I need a replacement remote control for my V+ box, but cannot find the appropriate option on 150 from my landline. There is no easy way just to speak to or contact someone. Any help, please?
I have replaced the batteries, re-booted the TV and there is still no life in the remote control.
  • 7.24K
  • 811
  • 3.05K
Re: i need a replacement remote control for my V+ box, but cannot find the appropriate option on 150
150 and select for TV faults.
http://community.virginmedia.com/t5/TV/Replacement-Remote-Control/td-p/1506736
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
