cheeky-chlo
help with recordings
Hello Im currently a sky customer with a communal dish, I was just wondering if I changed to virgin would i be able to watch one programme and record another at the same time as I am currently unable to with my sky. I recently moved and wasn't aware that this change would happen. Help
Tags (3)
  • 10.32K
  • 920
  • 2.1K
Re: help with recordings
With the Virgin Media TiVo box, you can record three programs while watching a previously recorded program or watch a live program while recording two others.
cheeky-chlo
Can I do that with a communal dish as sky havw told me they can't do it now I'm in a tower block with a communal dish
  • 10.32K
  • 920
  • 2.1K
Virgin Media cable is completely different from satellite.
Each property is connected by a co-ax cable to the Virgin Media network.
Your first step should be to check if your property can be serviced by Virgin Media as not all areas are covered by the network.
Check your postcode here:
http://www.virginmedia.com/
