Rebecca15
Wrong remote
I have accidently sent my tv remote with the tv box instead of virgin remote
  • 8.72K
  • 1.18K
  • 3.53K
Re: Wrong remote
Oops. If you do a search via google or any other search engine for the tv model and remote it should come up with sources for you to buy a new remote.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 8.64K
  • 584
  • 1.71K
Re: Wrong remote
Also for future reference you don't need to send remotes back as Vigin only issue new remotes for hygiene reasons any old remotes can be thrown away or recycled
