  • 6
Zebbo
Message 1 of 5
Virgin TV box not working after thunderstorms
Our second TV box, (standard box not TIVO), has ceased to function after last nights storms. Have tried the usual cold re-boot etc but it seems to be dead. It's only been fitted for six months will we get a replacement?
Thanks.
Pete
  • 1.19K
  • 34
  • 67
jonathanlouis
Knows their stuff
Message 2 of 5
Re: Virgin TV box not working after thunderstorms
hi zebbo im sure your mistaken buy that there is no way this can be caused buy thunderstorms because the cables are covered underneath in other words there underground so interfirence buy picture is most possible unless your in different area sky tv can cause issues because there signal is outside on a dish but virgin tv doesnt cause issues with their cables jonni
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Message 3 of 5
Hi Zebbo,
Welcome back and thank you for posting.
I'm sorry to read about the TV services here and would like to help. I've been testing the connection and can see that the services are running well now.
Can you tell me if this is still the case?
Take care.
Ben
  • 6
Zebbo
Message 4 of 5
Hi Jonathanlouis
It was the lightening that caused the fault but not via the signal cable. It had caused a power surge which had actually killed her TV not the Virgin box.
Luckily, all my stuff downstairs, including my Hi-Fi, all run off a mains regenerator which has in-built surge protection.
Thanks for your reply.
Pete.
  • 6
Zebbo
Message 5 of 5
Hi Ben
Yep, box is working fine, it seems it was the TV that got fried !
Thanks.
Pete
