lesleywood
V box stuck on 0
V+box stuck on 0. Have rebooted 3 times unsuccessfully
Helpful Answers
  • 10.13K
  • 1K
  • 1.88K
Re: V box stuck on 0
1. Check the batteries in the remote (if the indicator on top of the remote glows orange when you press the buttons the batteries are exhausted).
2. Press OK to clear any messages from the screen.
3. Try using "Channel up" (CH+) instead of the number buttons to move to the next channel.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
All Replies
  • 10.13K
  • 1K
  • 1.88K
lesleywood
Many thanks all working ok now
