Mariel
V+ box problem
v HD box error Ld04
Post options
on ‎11-01-2016 20:40
Hi wonder if anyone can help my v+HD box has an error Ld04 is there a way to manually reset the box? Its a Samsung if this helps?? Won't switch on..
  • 10.11K
  • 999
  • 1.87K
Re: V+ box problem
A failure in that part of the boot sequence is usually terminal. Give faults a call & hopefully you will get a replacement in before christmas.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
  • 20.19K
  • 732
  • 1.5K
Re: V+ box problem
Hi Mariel,
Thanks for your post and welcome to the forums. It's really great having you on board with us in the Community.
I'm sorry to hear you are having an issue with your V+ box.
I can see you have since called in to get things resolved. If you have any further issue's pop back and let us know.
Kath_F
