  • 5
nails666
V+ HD box stuck at Ld04
Hi, I've just tried to use my V+ HD box and found that it had crashed sometime last night and would respond to any commands. I tried holding down the power button to reset it and the display just changed to 'Stop'. I've unplugged it several times now and each time when it restarts it just gets to Ld04 and then sits there not responding and not outputting any signal.
Is there anything else I can try or is the box dead?
Thanks for any help.
  • 5.09K
  • 180
  • 311
Re: V+ HD box stuck at Ld04
Hello nails666,
Sorry to hear you're experiencing issues with your V+ box and I would like to welcome you back to the community.
I have been able to locate your account and I'm unable to connect to the box so I would like to send one of the team out to take a look at this for you.
If you click on the purple envelope at the top right of the screen you will see a message waiting for you with further details.
Speak to you soon
Rose
