drewmcf
V HD box - not pausing or recording
I had a V HD box installed yesterday and it seems to be working ok apart from that it doesn't allow me to pause TV or record - I think it should?
  • 10.11K
  • 999
  • 1.87K
Re: V HD box - not pausing or recording
If its a VHD box, no it won't. The only 2 types of box that record are the TiVO & the V+HD.
The V+HD looks like this:
Samsung V+HDSamsung V+HD
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
drewmcf
Thanks, the installer left a manual for a v+ hd instead of a v hd box hence my confusion!
  • 10.11K
  • 999
  • 1.87K
The VHD & V+HD share the same firmware, so most of the instructions will be correct, with the exception of the recording functions.
