  • 47
pudsuk
V+ HD Box - Noise
My V+ HD box upstairs, its really noisy.  Its like you can hear the hard drive making so much noise, fans etc.
The box is really sluggish and un-responsive.
Does anyone know if this can be replaced???
  • 10.12K
  • 1000
  • 1.87K
Re: V+ HD Box - Noise
The cooling fans can get noisy if they get clogged. If this is the main issue, run a vacuum cleaner around the outlet & it may clear the issue. If not then call faults. Sluggish responses can be caused by signal issues as well as box issues.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
  • 47
pudsuk
Will give it a clear out, I did look last night and it didn't appear to bad, but will give it a go. Cheers
  • 4.44K
  • 139
  • 333
Moderator
Moderator
Hi pudsuk,
Thanks for your post and I'm sorry to hear the V+ HD box is really noisy.
I can see nodrogd has already offered some advice around this which is greatly appreciated. Did you manage to give the vents a little clean as suggested and has the noise improved? I would have had a quick check over the box for you but I'm having some difficulties locating your account details. If you're still having trouble I can certainly take a further look at this for you, just let me know.
Stephen_B
Community Moderator
