  • 19
surfnode
V+ HD Box Hard Drive spins up every hour - noisy and annoying
The Hard Drive on our V+ HD box spins up every hour and especially at night time this is quite annoying with it whirring away for a few minutes before powering down - its got to the point of turning the box off and only turning it on when we need to use it.
Is this normal?
Thanks.
  • 10.14K
  • 1K
  • 1.88K
Re: V+ HD Box Hard Drive spins up every hour - noisy and annoying
Yes it is normal.
Is it the HDD or the fan? It could be either. If its spoiling your viewing as well, report it as a fault.
Turning off shouldn't affect things too much, but you might find if there have been overnight updates missed the box will take longer to start. Also the EPG may take a while to reach normal capacity.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
  • 774
  • 80
  • 149
LittleMick73
Well-informed
With this type of equipment it should not be turned off as it is reciving data all the time, however if it's very noisy I can understand. Micky
