chasemac
V+-Box Replacement by Tivo
I'm trying to copy stored programs on my V+ Box to a DVD recorder using the V+ Copy function, so that I can save them before installing my new Tivo Box.    It looks like the DVD Recorder saves the programs, but I cannot play them back.  Does anyone have any ideas ? The DVD Recorder is a Panasonic EX-78, which has a hard drive capability.
  • 10.12K
  • 999
  • 1.87K
Re: V+-Box Replacement by Tivo
Firstly, make sure you are using the VCR Scart to record from & not the TV Scart. If you are using the correct Scart, with the DVD recorder set to record from AV2, & you still have no picture, suspect the Scart lead is faulty. Try swapping the ends over (so the end plugged into the V+ is plugged into the DVD instead) this will elliminate a faulty connection in the cable.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
