  • 160
wilksbrighton
Tv sound and remote problem
My standard Virgin media box's remote has stopped working. On my my Tivo box, the sound goes in to a radio static. I also my broadband has been disconnecting a few times this week as well.
  • 6.73K
  • 269
  • 488
Re: Tv sound and remote problem
Hi wilksbrighton,
Thanks for posting!
Sorry you're having so many issues with your services.
I've ordered you a replacement remote control. That should be with you within 3 - 5 working days.
Can you check the cable connections in the TiVo®? Do you get any sound issues when you use any other devices connected to the TV?
I've run some checks on the broadband and TiVo® and the signal levels are all looking great.
Look forward to hearing from you!  Smiley Very Happy
Josh
  • 160
wilksbrighton
Hi Josh,
Thanks for sending out a replacement remote.
The sound is fine with other devices connected to the tv. The connections are tight on the Tivo.
  • 6.73K
  • 269
  • 488
Hi wilksbrighton,
Thanks for doing those checks for me!
I'd like to send a technician to take a look at it for you. I've sent you a private message (purple envelope at the top right of your screen) so I can get this arranged.
Josh
