  • 8
Pamdor
Message 1 of 5
Tivo box on standby moving 'no signal' indicator
When my Tivo box is switched to standby my television ( controlled by Tivo box remote) has two signals appearing on blank screen.  One indicates that I've no signal and the other HDMI1/DVI. How can these be removed? Annoyingly the 'no signal' warning moves up and down the screen....Any help appreciated.
  • 8.27K
  • 393
  • 972
jb66
Message 2 of 5
Re: Tivo box on standby moving 'no signal' indicator
The TV is displaying that message not the tivo, if you dont want to see it you can put the tv on standby
  • 8
Pamdor
Message 3 of 5
Hi thanks for response, however I'd hoped since my TV was controlled by the Tivo box remote, that I'd could lazy and control via Tivo box remote only. That said at least you have cleared up source of signal so much appreciated.
  • 8.27K
  • 393
  • 972
jb66
Message 4 of 5
If you hold the power button on tivo remote for 5 seconds it turns TV off
  • 8
Pamdor
Message 5 of 5
Hi thanks for that, however did not want to switch TV off as it is connected via Bluetooth to sound bar, which when TV is switched off also loses soundbar Bluetooth connection. Hence rather than keep switching sound bar on with Tivo box, my ideal solution was (via one remote only) is to all ( TV, Tivo and sound bar) on standby with blank TV screen.
Realise this solution is not possible on current set up so will need to have re-think.....help is much appreciated.
