Ashhext
Tivo box clicking noise
When my Tivo box is turned on it makes a constant clicking noise which stops when I turn the box off. Any suggestions on what this may be and how I can get this sorted?
Thanks!
  • 6.17K
  • 230
  • 353
Re: Tivo box clicking noise
Hello Ashhext,
Thanks for posting!
It sounds like there's a problem with the hard drive so what I would like to do is to arrange for one of our engineers to take a closer look.
I'm just going to send you a private message with appointment times which you will find if you click on the purple envelope at the top right of the screen.
Speak to you soon.
Rose
