Cadgerblock
TiVo Box, random reboot, then stuck in reboot loops.. hard reset required. repeats daily.
All,
As the subject says, we are getting random restarts of the Tivo Box, which then just keeps trying to restart then reboots (never makes it to the restart with clock). ultimately a hard reset is required to get it to restart properly again.
The above is happening at least once a day, time appears to be random.
Engineer been out once, and checked local lines and all connections - tight and no faults.
Been on the phone and no real answers apart from sending an engineer out again ~ guessing its a box fault but when its up and running, no issues ?? would a faulty power connection or something cause these restarts then reboot loops ? would expect a power loss to not cause the reboot loops however, especially as the hard reset sorts it out??
Any Ideas ?
J
  • 8.02K
  • 423
  • 1.3K
Re: TiVo Box, random reboot, then stuck in reboot loops.. hard reset required. repeats daily.
Did the tech replace the power supply when swapping out the TiVo?
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
