daykz69
TV Anywhere not working for BT Sports
TV other not working on had Pro for IT Sports?
Can anyone from the forum or virgin media help?
  • 11.07K
  • 1.02K
  • 2.26K
Re: TV Anywhere not working for BT Sports
Are you using the correct channels, 531-534?
daykz69
Hi Ernie
Just read my original post and looks like predictive text took over 😡 It's not the channels, it's TV Anywhere App that's the issue.
TV Anywhere has stopped working on the IPad Pro, used to be fine for watching sports channels but no longer works.
Any support much appreciated
daykz69
Ernie
You're a star, seems to work having input to the channel number manually on the App.
