  • 9
Mrleeuk
TV And Broadband issues. Signal Strength???
I seem to be having a problem with both the Broadband and signal strength on the TV.  Both boxes (Tivo and V+ Box) show pixels every now and then.  The only way to describe it is as though you are watching digital TV and the signal strength is not strong enough.  I am also experiencing slow speeds with my Broadband.  I have tried resetting everything and nothing seems to solve it.
Could this be a problem with the strength of the signal coming to my home?
Regards,
Lee
  • 7.75K
  • 333
  • 542
Re: TV And Broadband issues. Signal Strength???
Hi Mrleeuk,
Thanks for posting!
Sorry to hear you're having trouble with your TV and broadband.
I've run a diagnostic and I can see an issue with your Signal levels. This is likely what's causing your pixilation and speed issues.
I've sent you a private message (purple envelope at the top right of your screen) so I can arrange for a technician to adjust these levels.
Look forward to hearing from you!  Smiley Very Happy
Josh
