  • 7
Coop1878
Message 1 of 9
Surround sound sky movies
Have just moved over from sky. Have the movie HD channels and can't seem to get the sound in 5.1 on my home cinema system. Can anyone help me it's driving me crazy. Had no problems at all with sky.
  • 7
Coop1878
Message 2 of 9
parental control
Keeps asking me for a passcode everytime I go on a movie channel before 8pm. Driving me crazy. How do I stop this?
  • 17.31K
  • 1.58K
  • 2.96K
Message 3 of 9
Re: parental control
How are you connecting to your home cinema system? Via HDMI passthrough or via Optical?
In regards to the PIN, it's an OFCOM requirement that Sky Cinema channels are PIN protected where the content is shown outside the watershed for it's rating for both live channels and recordings for Sky Cinema. It is the same for Sky's service, although the behaviour may be slightly different.
  • 7
Coop1878
Message 4 of 9
Currently with an optical cable. I've noticed when you press 'info" on the remote it doesn't even specify what sound is available. When you go to the audio on the left hand side it just says English Dolby digital. Should that be 5.1 ?
  • 17.31K
  • 1.58K
  • 2.96K
Message 5 of 9
TiVo only shows 'Dolby Digital' as some HD channels with DD actually only have DD 2.0, rather than 5.1.
I'd check in Help & Settings > Settings > Audio that the correct setting for your audio system is selected.
As long as your audio system is saying it's getting a DD signal, then it's down to the channel and programme as to whether it's DD 2.0 or 5.1.
  • 10.12K
  • 999
  • 1.87K
Message 6 of 9
You can't. It is a restriction that has been imposed on Sky & any third party that takes their movie channels by OFCOM. It is a condition of showing movies outside of the normal watershed restrictions that PIN restrictions must be "locked on" irrespective of the setting the customer has on their box.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
  • 7
Coop1878
Message 7 of 9
Thanks. Having had sky movies for years I know those channels have 5.1 audio. Why I was so surprised when I have moved over.
  • 773
  • 79
  • 149
LittleMick73
Well-informed
Message 8 of 9
Re: Surround sound sky movies
Hi connect optical from amp direct to tv, you are connected from tivo to tv via hdmi so it will just take a different route. If your tv doesn't optical, think about buying a slightly higher spec next time. Regards Micky
  • 7
Coop1878
Message 9 of 9
Sorted Mick , thanks mate. You may not know but worth a shot , I also have a PS4. This has an optical output but my TV only has one optical & as you suggested is now going TV to amplifier. So my PS4 is not in 5.1 as I know it should. Drives me nuts. Any ideas ?
