Greenyspaced
Sound interference
Anyone experiencing sound interference with TiVo through 5:1? It does not seem to be the amp or connections. Only effecting the front speakers. Cheers for any advice
Tags (3)
  • 7.25K
  • 281
  • 547
Re: Sound interference
Hi Greenyspaced,
Welcome to the community Smiley Happy
I'm sorry to hear that your experience interference with the sound right now.  I'll be happy to help check this out.
I have taken a look at your box remotely and all looks fine from here signal wise.  Have you tried powering off/on the box to refresh things?  If not, give this a try and let me know if this helps.
It's also worth checking the Audio settings.
HOME > SETTINGS > AUDIO > DOLBY DIGITAL > DOLBY DIGITAL TO PCM.
If you follow these steps and change it to the above setting and see if that helps.
Let me know how you get on Smiley Happy
